Thread: Stock Fork Height
Created on: 10/23/21 05:17 PM
Fnshrmaster
Stock Fork Height
10/23/21 5:17 PM
I just bought a 2015 30th Anniversary 14R. It has a roaring toys 8" extended swingarm which I plan to remove and sell. The forks are lowered in the triple clamps to match the rear lowering links. My question is, where do I take the measurement from to return to the stock .85"?
Anyone need a complete air shifter kit and extended swingarm? Both high quality pieces, installed professionally.
Thanks, Kurt
RE: Stock Fork Height
10/23/21 8:08 PM
Welcome, Kurt
Correct, the number you mentioned is from out the top of the crown, and the 85 inch stops at the fork leg's tube, not the top cap. So as if the cap is off the fork, that's your inches out the top crown.
So it's 15ft torque at the top crown pinch.
Back and forth going up to 18ft on the lower tree and they change if you just yank it to toque and then the other. More like 5 back and forth, then 10 the same way, 15 and last torque at the pinch bolts is 18.
You're not done. This is wheel off, axle needed. Then you float the other fork and find the sweet spot of the axle spinning in the other leg. You want it squared to the triple in other words. Lock that fork down and check for axle spin.
It's more for handling than for easy wheel service.
Fnshrmaster
10/23/21 9:38 PM
Thank you, Hub. Appreciate the clarification.
Kurt
Fnshrmaster
10/24/21 12:01 PM
Hub, is that measured with the clip ons removed?
Kurt
10/24/21 1:58 PM
Yes.
